November 27, 2024, 01:58:46 pm
| | | |-+  Switching Forum Hosts...
Author Topic: Switching Forum Hosts...  (Read 1727 times)
« on: May 19, 2005, 04:41:25 am »
Maybe somebody will know the answer to this, maybe not.
We have to switch the host of our forums, problem is that we are going to be switching from a Unix based Apache server to a WebSTAR server.  We were just wondering first of if it's possible and second off how to do it, we would just need the root path.
Monoman
Oh Canada!!
« Reply #1 on: May 23, 2005, 11:30:13 am »
After a quick check of the readme for SimpleMachines, you should be find as long as PHP and MySQL are supported.
From the readme:
Your server must meet a few requirements to be able to run SMF. If you unsure as to whether your webserver meets these, please try the installer - it should detect any problems.
*   Any webserver that properly supports PHP, such as Apache or Internet Information Services (IIS).
*   PHP 4.1.0 or higher. The following directives are required to be set correctly in php.ini:
*   the engine directive must be On.
*   the magic_quotes_sybase directive must be set to Off.
*   the session.save_path directive must be set to a valid directory.
*   the file_uploads directive must be On.
*   the upload_tmp_dir must be set to a valid directory.
*   MySQL 3.23.4 or higher.
*   at least 512 kilobytes of storage space in the database, although more is highly recommended.
*   about two and a half megabytes of storage space on the web server, although more is recommended.
Recommendations for best performance:
*   Linux or another Unix based operating system.
*   the GNU Aspell and its dictionaries for spell checking support.
*   Apache with AcceptPathInfo set to On (Apache 2 and later only) for queryless URL support.
*   PHP 4.3.0 or higher, with the following set in php.ini:
*   the max_input_time directive is set to a value of at least 30.
*   the post_max_size and upload_max_filesize directives are set to the size of the largest attachments you wish to be able to upload.
*   the session.use_trans_sid directive set to Off.
*   the memory_limit directive is set to at least 8M.
*   the max_execution_time directive is set to at least 15.
*   the register_globals directive is set to Off.
*   MySQL 4.0.15 or higher with query caching enabled.
*   GD Graphics Library 2.0 or higher.
Kansas....Like Paris Hilton: White, Flat, and Easy to Enter.  -- Conan O'Brien
Page created in 0.049 seconds with 19 queries.
