September 29, 2024, 06:25:10 am
cookie
Airsoft
Topic: Airsoft (Read 1496 times)
bloodanguts
Blood for the Blood God!
Airsoft
May 01, 2005, 10:09:53 pm »
Anyone else play airsoft?
I just recently got myself a G3/SG1... it kicks ass
Re: Airsoft
May 01, 2005, 10:13:25 pm »
Yeah, Typhy does.
[/size]
KoS.Rebel
+-Killers on Spree-+
Re: Airsoft
May 02, 2005, 01:33:31 am »
I have before...but i dont do it often.
The extent of one's abilities is only limited by the restrictions of one's mind
Overthrow.aHa!
Re: Airsoft
May 02, 2005, 02:38:27 am »
bah
paintball is where its at
Re: Airsoft
May 02, 2005, 03:06:08 am »
I'm using a Tokyo Marui M4A1 most of the time right now, 375 FPS upgrade, Steel Bushings & Systema High Torque Gears. 6.03mm Tightbore barrel. 9.6v 1700Mah battery.
I've also got a TM MP5J, M100 spring, tightbore barrel, chronos right around 340 FPS, custom 9.6v 1100Mah battery. That's my CQC gun now'a'days.
Also a TM P90, Mil Steyr Aug and an ICS/AE MP5A4.
The G3/SG1 is simply too big, the only way I could see using one of those is upgrading your internals to around 450 FPS and using it as a sniper.
I'm doing both Paintball and Airsoft these days. Paintball about twice a month, and airsoft once a week or so.
Re: Airsoft
May 02, 2005, 04:54:17 am »
Quote from: Typhy on May 02, 2005, 03:06:08 am
450 FPS
OMG nice framerates!!!
On a more... well... on topic note...
I have an AR-15 that I use to hunt wasps.
It's actually a lot of fun... and what an adrenaline rush when you miss!
Last Edit: May 02, 2005, 04:55:52 am by -MP5-SNiPE-a2-
Re: Airsoft
May 02, 2005, 02:41:28 pm »
lol snipe, i bet you learn to hit them pretty quick... i got some ointment for those stings somewhere if you want
bronto
Re: Airsoft
May 02, 2005, 07:21:55 pm »
wifey is a crazy one
Re: Airsoft
May 02, 2005, 10:15:56 pm »
Quote from: BFG on May 02, 2005, 02:41:28 pm
I actually sent Typhy a photo of one I shot. Here it is:
bloodanguts
Re: Airsoft
May 04, 2005, 07:07:00 pm »
Mine is only stock... the 'rents didn't feel like spending any more then needed
although I may try and get some upgrade parts in the future.
It is kind of unweildy due to its size, but i still love it. Although the range isn't as long as it could be upgraded to, it still makes a good sniper even at stock level, and as except for very close ranges, its a good all round weapon. I do wish I hadn't gotten it though and waited for the M14 to come out. I love M14's... even if it is almost 200$ more
Re: Airsoft
May 04, 2005, 08:26:15 pm »
The G&G M14 is really nice, but it has some issues too, like no std. mags, just high caps.
The problem with stock guns that size is that their performance is almost the exact same as that of a stock MP5. The velocity isn't high enough to take advantage of the longer barrel.
bloodanguts
Re: Airsoft
May 05, 2005, 01:27:21 am »
ya, but the reason I got it (besides G3's just being cool) is that from what I've heard, its a great gun if you have plans of having a starting place to slowly upgrade from, which is what I hope to do eventually.
Re: Airsoft
May 05, 2005, 02:03:45 am »
So is anything with a barrel past 350mm.
You have to decide what kinda role you want to play. Here, 375 FPS is standard on all assault rilfes ( Systema Steel Bushings, PDI 130% spring, and a 9.6v battery ). If you want to use it as a sniper, you might want to go up to 450 FPS, but that involves high torque gears, bushings, piston, piston head, cylinder, cylinder head, etc.
I guess my biggest problem with the SG1 is that a gun like the Steyr Aug actually has a longer barrel, yet is far shorter and easier to manuver with.
With something the size of the SG-1, you're pretty much locked into sniping. You try and go into close quarters, you're going to get lit up by an MP5, midrange an M4 will blow you away, and even long range you don't have much of a prayer against PSG-1s or bolt action snipers.
I just have trouble seeing what you can do with an SG-1 that you can't do with a smaller weapon.
If I were you, I'd kick in about 75 bucks ASAP. Go up to 375 FPS, and pick up a 9.6v battery so your ROF doesn't go to hell with the power upgrade. From there, I'd go with a tightbore barrel, either 6.03 or 6.04mm, anytime you want to pick up 10-15 FPS without effecting your ROF or gearbox, pick up a Systema Air Nozzle, about a 5 dollar upgrade that'll improve your performance a bit.
bloodanguts
Re: Airsoft
May 05, 2005, 03:17:20 am »
I've been looking at the upgrade package on airsoftatlanta.com Pretty affordable (<100$), and it at least claims to up speed to 400Fps. Probably not going to upgrade yet though, as some of my friends still have springer shotguns, and I would just feel evil shooting them
bronto
Re: Airsoft
May 05, 2005, 03:23:12 am »
i don't know anyone who plays airsoft, but i'm about to get one of these...
bloodanguts
Re: Airsoft
May 05, 2005, 04:15:29 am »
Tell me where u live... so I can kill you and take it
Re: Airsoft
May 05, 2005, 07:56:19 am »
Juneau, Alaska. I play at several locations, out around 34 mile in the woods, at the Warehouse out Thane, woods at 8m thane, and a rock courie at about 4m N. Douglas.
Quote from: bloodanguts on May 05, 2005, 03:17:20 am
So you could pay AA 100 bucks to do it, or you could do it yourself for about 25. I can walk you through your gearbox workings if you want to do it on your own.
AEG vs Springers isn't really even fair, I've got a spring AR15 that I use when I play against people with springers, the AEG simply has too much firepower.
Yeah, yeah, thanks Lone.
Last Edit: May 05, 2005, 09:50:46 am by Typhy
DarK.
Forum's Evil Side
Re: Airsoft
Reply #17 on:
May 05, 2005, 05:38:52 pm »
Quote from: Typhy on May 05, 2005, 07:56:19 am
I think you mean quarry typhy, anyway Ive got one of those shatty 20 dollar Mp5's lol its quite shatty so I stick to paintball.
Arguing on the internet is like running in the special olympics... Even if you win, you are still retarded.
bloodanguts
Re: Airsoft
Reply #18 on:
May 06, 2005, 12:22:37 am »
I'm probably going to (try to) do it myself, as it would mean shipping it there. Although there is a store a few towns over, and they might be able to do it for me cheaper...
Playing with Springers actually isn't as unbalanced as it would seem, mainly since I only have stock at the moment. But like I said, I would feel evil if I upgraded at this point...
I do have a messed up Shotgun though, but I ussualy lend it to friends. Its actually pretty good though, since I extended the barrel and put a better spring in it (It had snapped in half, so I had to take it apart and piece it together again).
Re: Airsoft
Reply #19 on:
May 06, 2005, 12:48:53 am »
Yeah, it's incredibly uneven. You can shoot a lot farther with the AEG, and about 30 times as fast. It's also a lot more accurate.
As long as you understand how your AEG works ( battery, motor, gears, piston/spring, cylinder, air nozzle, anti reversal latch ), and you're very patient, you can always do it yourself. Just remember, the less "extra parts" you have at the end, the better.
