April 04, 2025, 03:21:07 am
| |-+  *DAMN (Moderators: *DAMN Mauti, BFG)
| | |-+  DBL Map Pack 2.55 Complete.
Author Topic: DBL Map Pack 2.55 Complete.  (Read 9654 times)
[:] Narauko
the Germans call this BEER?!?
« on: January 20, 2005, 01:53:49 am »
Hey guys i know its been ages since u released it, but i recently had to reinstall Ghost Recon and didn't use the complete download last time. Anyway...My question is when i download the DBL Map Pack 2.55 Complete it downloads fine but when i unstuff it my comp doesn't recognise it as an installer and install it says there is no default application for this and i should choose one, it says application when i check info.
Narauko.
War is a hobby, one Fucked Up Beyound All Recognition game.
[/color]
« Reply #1 on: January 20, 2005, 03:24:54 am »
I had that same problem.  I was using Firefox at the time I believe and I tried downloading it with Safari and it worked fine.
[:] Narauko
« Reply #2 on: January 20, 2005, 07:16:56 am »
a fellow clan member sent it over ichat (hope you don't mind damn). But i'm using IE so im confuzzled why it happened first one was fine DBL MP 1 that is.
[/color]
« Reply #3 on: January 21, 2005, 12:41:55 am »
Sometimes it is the unzip from the Finder that screws our installer. Use expander instead and it should work fine.
[:] Narauko
« Reply #4 on: January 21, 2005, 03:52:00 am »
ok thnx for the info.
Narauko.
[/color]
Subucni
« Reply #5 on: April 21, 2005, 03:04:51 am »
I tried opening from expander but that didn't work either. Is there anywhere I can download an unzipped version?
Thomas
« Reply #6 on: April 21, 2005, 08:01:58 am »
Hi Subuchi,
please read http://www.damnr6.com/yabbse/index.php?topic=7977.0 and try it out. It helped everyone so far, who had problems.
Sucubni incubuS
« Reply #7 on: April 22, 2005, 04:47:48 am »
I've been there. It said to download in OSX which is where I was already. It also said to drag'n'drop on expander but that doesn't work either.
No troubles downloading but the resulting file is unusable.
Any ideas (or uncomressed sources)?
Thomas
« Reply #8 on: April 22, 2005, 08:36:42 am »
Well please check the filesize and post it here, may your download was interrupted. Further make sure that the *DBL 2.55 complete file has suffix .zip and not .sit. What does Expander say!?
Once the file has been unstuffed you have to double click the file - it's an installer.
Subucni
« Reply #9 on: April 22, 2005, 03:24:37 pm »
The file info is below. I can download it with no problems with IE or Safari and Expander has no problem expanding it.
The __MACOSX folder is empty (just a way of leaving a note maybe?) and if I doubleclick on the document this happens:
Thanks for all your help so far Mauti. I appreciate it.
Thomas
« Reply #10 on: April 22, 2005, 05:03:26 pm »
I had that problem once in fact my post is still up at the top there.  I was using Firefox and it was doing something to the download so that it wouldn't work but I switched web browsers and it was fine.  I don't know if that's the browsers fault or what.
« Reply #11 on: April 22, 2005, 06:08:27 pm »
Subucni - the .zip is missing of the file if you add it on (so that the file is called *DBL Map Pack 2.55 Complete.zip ) then your comp will recognise the file and Stuffit will open it... - im guessing you have allready tried clicking on "choose application" browsing to Stuffit and trying to open it that way?
Subucni
« Reply #12 on: April 24, 2005, 02:40:40 pm »
Stuffit doesn't recognise the document as a stuffed file whether I put .zip on it or not.
I don't think there is anything else I can do at this point. I still think the best way is to find someone who can give me the uncompressed files or find another download site that maybe has files that I can get to work.
Any more ideas guys?
Thomas
- Can't make up my mind whether that Tennessee quote is as funny as it is scary! -
« Reply #13 on: April 24, 2005, 03:48:52 pm »
Hmm dosn't sound like your having any luck with this!
Just a  last question to see if we can solve it: When you click to "choose application" to try and unstuff the file what error does stuffit throw at you?
ps. hehe its a Tough call... but i think scary wins it Wink
Subucni
« Reply #14 on: May 05, 2005, 04:22:29 am »
I reread some of the threads where the guys had solved the problem and it occurred to me that it is probably a system software problem. I can run this map pack in Mac OS 10.2.8, right?
The reason I ask is that I finally got a slightly different result by booting up in OS 9, downloading and unstuffing the downloaded file. The difference was that there is now a copy of the mappack file in the __MACOSX folder. It doesn't work either but at least it's there!
When I copied the unstuffed folders and files to my desktop computer ( OS X.2.8 ) the mappack inside the __MACOSX folder had dissappeared again. I'm guessing this is a permissions problem?!
I still think I would be better off downloading this without compression. Do any of you have this on an ftp site?
I have never used emoticons but this one seemed so appropriate: wallbashing
Thomas
Mauti have you seen/played Toyspring's Bike Or Die for PalmOS?
Subucni
« Reply #15 on: May 23, 2005, 07:48:54 pm »
I finally solved this by downloading to another machine. I think the problem lies in the combination stuffit + OS X.2.8.
Be very afraid - now I have the dbl's I am coming after you all!
So what if you have a few years experience to beat me with - I'll bite your ankles as you walk over my body!
See you in my sites,
T
z][t-Primary
« Reply #16 on: July 24, 2005, 03:47:17 pm »
yeah i had this problem too, and i had to unstuff it using the Finder expander thingie on my mom's PB, which had OS10.3 as opposed to my 10.2. (10.2 uses Stuffit)
Subucni
« Reply #17 on: October 11, 2005, 07:03:19 pm »
Well, I hadn't solved it after all! I have since switched to 10.4 and my G4 tower still cannot unpack these files - I just had the exact same problem on downloading the DBL Final file.
Luckily my little G3 iBook manages it no problem and then passes it to it's big brother.
Still a mystery...
« Reply #18 on: October 11, 2005, 07:28:57 pm »
Subucni, are you using the latest version of Stuffit? everyone im aware of has solved it by making sure they are using the most uptodate version to expand the file.
Page created in 0.066 seconds with 19 queries.
