February 18, 2025, 11:28:00 pm
| | |-+  RS or UO Main Menu Pic...how do i change it?
Author Topic: RS or UO Main Menu Pic...how do i change it?  (Read 1662 times)
osiris263
« on: April 29, 2003, 02:04:37 am »
in UO, or Rogue Spear, where is the pic that is on the Main Menu located? (the one where in UO its the guy with the assult rifle, RS is the Arctic man...) i assume its in data/splash or bitmap (or something like that), if it is, what is the file name                     Huh   Huh Huh
« Reply #1 on: April 30, 2003, 12:36:43 am »
It's in the splash folder, and others are in the textures folder (menu backgrounds, borders, etc...)
Rigid Ice
Why dodge bullets when you can just suck 'em all in!??
« Reply #2 on: April 30, 2003, 01:19:58 am »
For just what you are asking for, the file is in the bitmap folder and is named "mm_bg00.rsb" the "mm_logo.rsb" can also be used- if you make it all that one pinkish color, it is transparent!
Silent Strike Mod almost ready for public distribution- get feedback from beta testers, put up final mod, put up site, and voila! Maybe a couple days or week (s) remaining!- web space down- cancelled for the moment
« Reply #3 on: May 01, 2003, 07:33:01 pm »
Here's a trick. The logo image and the background image have a strange relationship. The background is there and the logo appears and fades in slowly. You want to use part of the background behind the logo, but you want it to come in corrctly aligned. Here's the deal:
[1] finish your background image, don't add the logo text to it though.
[2] create your logo image, and drag the background image into the frame and line up the upper right corner, do not change any dimensions.
[3] Here's the problem. Aligning it this way will result in a slightly off-center logo and noticeable lines around it. What you need to do now is move the layer you dragged into the logo frame over to the right 5 PIXELS. Keep the upper edge aligned with the top of the frame and just move it to the right. This will correctly align it and it will fade in perfectly. Wink
You can make the logo the pink transparent color and it will not appear at all, but the fade effect is hot and I always try to use it to it's full potential, it's kind of dramatic...
Page created in 0.102 seconds with 19 queries.
