November 28, 2024, 03:42:53 am
| | |-+  B&W G3 IDE question...help PLZ!!
Author Topic: B&W G3 IDE question...help PLZ!!  (Read 1162 times)
BTs_Colin
Not Gorfs Brother
« on: April 17, 2003, 02:08:13 am »
Ok I just got a nice new 60GB Seagate 7200rpm drive.
 My Mac has a 9GB SCSI drive mounted at the bottom. Now my Mac is unique in that it is a rev2 mobo (checked the IDE chip) but it does not have a dual drive bracket for mounting another HD. I think this has to do with the fact that it says Macintosh Server G3 on the back.
 So what do I need to install this drive in the easiest way possible?
 If you need more information to help don't hesitate to ask. Thanks for the help.
_________________
B&W G3/400, 320MB RAM, 9GB UW SCSI, Internal CD-RW, 32MB DDR Radeon Mac Edition
i'm the DP facial when your searching for teen
ShadowBox
No Hump = No Own
« Reply #1 on: April 17, 2003, 04:27:44 pm »
Colin
     Check out http://www.xlr8yourmac.com for some instruction on mounting additional hard drives in your Blue & White. If you bought a retail box hard drive, it should be as easy as screwing it into the 3rd position (toward the back of the machine) of the base plate.
|F| ShadowBox
No Hump = No Own
BTs_Colin
Not Gorfs Brother
« Reply #2 on: April 18, 2003, 10:35:25 pm »
Ya you would think that anyway.
Well I got it sorted out but I have another problem.
It won't show up in OS X. It works fine in OS 9.
Any ideas?
Snipes
God Bless The Freaks
« Reply #3 on: April 19, 2003, 04:11:24 am »
I have noooooo idea...
Snipes
Email: johnzy@excite.com
AIM: FreakDork685
GameRanger ID: 28710
www.turning.to/sgt
Snipes Gun Targets
« Reply #4 on: April 19, 2003, 09:28:52 am »
Then why did you post, Snipey? If you have no idea, then stay out.
If everyone acted like you ( god forbid it ), topics like this, asking questions, would get about 691 replies saying "I have nooooooo idea..."
If you have "no idea", then don't respond. Clear?
« Reply #5 on: April 19, 2003, 11:12:04 am »
     Colin, can the OS X Disk Utility see the drive? If yes, then you should be able to reformat it and install new drivers on it, and everything should be hunky-dory. If no, you may be S.O.L. When I got my G4, I moved one of my hard drives from my old computer into this one. No matter what I did, I could not get the G4 to see it. I even tried formatting it on the old computer and reinstalling the drive into the G4, but no dice. I never found a reason why it didn't work, either.
*DAMN Elandrion
« Reply #6 on: April 19, 2003, 03:07:49 pm »
did you check the jumper settings on the new HD? if you have 2 devices connected to your ide port, one should be master, the other slave. if the jumpers are correct, try disconnecting the second device and try to run the HD alone (as master)...
BTs_Colin
Not Gorfs Brother
« Reply #7 on: April 20, 2003, 01:59:06 am »
ya i guess i will try just using the HD as master.
loth I am shocked to hear that and i hope it is not the case. i will try to format it in my dad's G4 and install it in the G3.
and no Disk Utility didn't see the drive. But Drive Setup (OS9) worked fine.
Strange.
Typhy,
I can't belive you take the time out to chide someone for posting OT and then don't provide any On topic insight. lol. just ironic
BTs_Colin
Not Gorfs Brother
« Reply #8 on: April 22, 2003, 08:26:45 am »
fixed and i got a new logitech keyboard
ggs all around
Page created in 0.055 seconds with 18 queries.
