November 24, 2024, 09:06:23 am
Author Topic: New rules for ghr  (Read 1545 times)
« on: March 14, 2003, 05:53:14 pm »
Here is a set of rules for ghr that I got offline off www.thecombatzone.net/modules.php?name=Rules_GR.  I think that these rules are a little more exact for the game although there is still a few loopholes as well.  But in the end these rules I believe would eliminate the tie problem, that's for sure =) :\
 Ghost Recon Rules
Ghost Recon Game Play Rules
Valid Maps and Game Play
1.? Only stock maps from Ghost Recon (Including Desert Siege and Island Thunder) and RSE/Ubi Soft are allowed in game play.?? This is considered the stock rule should we add a custom map rule.? Modified game files, tweaks (mods), custom enhancements are not permitted and grounds for ejection from the ladder.? Exceptions are based on the request of the matching teams or?otherwise noted by The Combat Zone Administration.
2.? Current Invalid Maps: NONE
Restrictions: 2v2 Ladder:? ONLY Multiplayer Maps, Embassy, Refinery and Polling Center are allowed.? Wilderness is Restricted and NOT Allowed.
Restrictions: 1v1 Ladder:? ONLY Multiplayer Maps are allowed.
3.? Only stock (default) uniforms allowed.? No custom designs as of yet.
4.? Only stock (default) weapons allowed.? No restrictions on weapons as of yet.?
5.? The smallest match roster required for a challenge is 3.? If a team is challenged to a match they are required to accept the match with in the guidelines of the rules.
Except in 2v2 Ladder (min. roster = 2) and 1v1 Ladder (min. roster = 1).
Mods and File changes are not allowed.?
Exceptions: Options.XML file can be modified as well as a Command Map Grid Overlay Mod employed.
Command Map Mod must meet the following criteria:? Client Sided.? Non-Overwriting of original game files for an inception of an Anti-Cheat Program Install.
Game Play and Settings
1.? Matches will be composed of the Best of 3 games.? You could play a total of 3 maps, each played 3 times.? Map 1 - (2/3) Map 2 - (2/3) Map 3 (If Needed) - (2/3)
For understanding purposes:? Game means 1 Map played for a Best of 3.? You will play up to 3 games to determine a winner.? Which means you could play no more than 9 times.
For ladders with a time limit.? When the time runs out the game will note the winner of the map.? This result is valid.? In the event of a DRAW or Tie that map needs to be played again.
2.? In All Matches (Except 1v1):
- 1st map is to be selected by the lower ranked team (player).? The higher ranked team (player) will select the side and color (Team Selector).
This round is played up to 3 times.
??- 2nd map is to be selected by the higher ranked team (player).? The lower ranked team (player) will select the side and color (Team Selector).
?- 3rd map (If needed) is to be selected by the lower ranked team (player).? The higher ranked team (player) will select the side and color (Team Selector).
?- The same map can be chosen.
?- Team choice of side must be complete.? No splitting up of team.
There can be NO TIE (DRAW).? If needed the map is to be redone till you reach a winner.
1v1 Map Play:? Each round is to be played only once.
In the event of an uneven match and both sides are wiped out: :? The game will not issue a draw as normal but a win to the team with the lesser amount of players (read: most kills).? This is a valid win.?? For ALL matches the result that the server declares is valid.
REGARDING REPLAYS:? ALL replays must be handed over to the opponent at their request with in 24 hours of the match completion.? Failure to do so can lead to suspension up to and including ejection of the offending team.? Replays must be from the match in question.? We will not review replays from games outside TCZ other than for archiving purposes.
3. Game Settings for Hosting: Server Side
Identify Friend or Foe: RETICULE
Use Threat Indicator: OFF?(Except: 1v1 ON)
Random Insertion Zones: ON?
Time Limit: NONE (Except: Timed Ladder 15 Minutes, 2v2 Ladder 5 Minutes, and 1v1 Ladder 5 Minutes)
Game Mode: TEAM
Type: LAST MAN
Next Map: SAME (Player Choice)
Respawn: NONE (Except: 2v2 and 1v1 Ladder Setting:? INFINITE with 5 Second Invulnerability - 10 Second Respawn Delay)
Map Reps: 1
Available Kits: NO RESTRICTIONS (Except: Timed Ladder and 2v2 Ladder? - NO Sensors)
Auto-Start Timer: OFF (3 Minute Maximum In-Between Games turn to ON if needed)
Allow Observers: OFF
Arcade Mode: OFF
AI Backup: OFF
Random Teams: OFF
Team Selector:?1 (Color choice of Team) 2 (Color choice of Team)
Replay: ON
If needed use the Client and Server Replay Program to save multiple replays automatically and download them as needed.?? This file can be found in our: Download Section for Ghost Recon Utilities.? These replays are for the matching teams and if needed to be provided to the administration.
PsYcO aSsAsSiN
A blast from the past...
« Reply #1 on: March 14, 2003, 07:04:18 pm »
This wouldn't solve any tie issues because all PC clan battles are played on neutral or acceptable servers - there is no switching hosts like there is in the Mac cb's.
Rainbow 6/Rogue Spear/Ghost Recon/Raven Shield/America's Army/XBOX 360: Mighty Bruin
-retired- (MIA 6/17/02)
Hasta la vista, baby!  Embarrassed
Co-Leader, clan PsYcO.
Clan PsYcO - 11/01/00 - 02/08/02
R.I.P. Grifter
TRIBE_Horda
www.tribeclan.fr.st
« Reply #2 on: March 15, 2003, 04:37:01 am »
well take what is good in these rules and leave what is bad
I think  its a good idea how look other leagues
----[TRIBE]Clan----
http://www.tribeclan.fr.st
TRIBE_Horda
www.tribeclan.fr.st
« Reply #3 on: March 16, 2003, 06:49:53 am »
think Mauti has already fish ideas at the combat zone:
The Combat Zone Network Community and Ladder Rules
E.? Substitution - Teams can substitute players as often as they need in between rounds.? You have ONE 5-minute grace period to wait for a substitute before you must play short handed.? After that you are then allowed a maximum 3 minutes in between rounds before you must continue the match.
----[TRIBE]Clan----
Blitz
Pride and dignity mean nothing on the battlefield!
« Reply #4 on: March 28, 2003, 04:24:52 am »
 Grin Grin i really like the fact that these rules seem less confusing. Also, you can play multiple cb's in one day, which means more points.  That way you dont have reschedule every time someone has to leave or it goes on for 4 hours.
I WILL EAT YOUR SOUL!!!!! RRRRRRRRRRRRRAAAAAAAAAAAWWWWWWWRRRRRRRRR!!!!!!!!!
BTs_eight
Ka-BoOM!
« Reply #5 on: March 28, 2003, 09:49:08 am »
How about some dedicated servers thta are dedicated for cbs by neutreal parties...
for example...
I host a dedicated server for a cb against a euro based clan and a usa based clan... I cant help either clan out by peeking... nor would i want one clan to win over another since i just want all clans to lose =P
But maybe this can help?
Some east coast dedicateds for CBs... for euro vs usa... and some neutral dedicated on each side of the map....
For example i wouldnt be able to host a cb like Animal clan vs Tribe... but maybe... (ONLY EXAMPLES GUYS....) Agt vs c|...
Ya dig?
*DAMN VOODOO GOT CAUGHT!
Page created in 0.053 seconds with 18 queries.
