November 01, 2024, 07:28:34 am
| | |-+  A weapon for the HK mod... Idea
Author Topic: A weapon for the HK mod... Idea  (Read 1715 times)
Johannes
« on: May 07, 2001, 07:42:53 pm »
There is a Pistol which was made 1970... Called VP70... Volkspistole 70, sadly but no longer in production.
I would like to see this Pistol both in 3 round burst mode and single shot in this great HK mod. just an Idea.
More information can be found on http://www.hkpro.com/VP70.htm
Joe
« Reply #1 on: May 07, 2001, 09:04:02 pm »
Hmmm...That might be real interesting. Should not be much of a problem. I will build one model without the stock and one with out. 3 round burst on one, standard pistol on the second. Thanks for the info. Smiley
« Reply #2 on: May 08, 2001, 09:14:24 am »
you guys are killing me!!!!!
Ghost
MY OTHER CAR IS A HK PSG1
« Reply #3 on: May 08, 2001, 11:57:27 am »
The very first H&K Pistol ever made was the Model 4, so named because it was originally available in 4 calibers, .380 ACP (9x17mm), .32 ACP (7.65mm), 6.35mm, which I believe is .25 ACP, and .22LR.
It should also be known that all H&K submachine guns are available in different rate of fire combinations, single shot, two round burst, three round burst, four round burst, FIVE round burst, and full auto.
There was also a 5.56mm variant of the G3 family, the G-41, with attached 40mm grenade launcher, it is the G-41TGS1.
You can also mix and match stocks, triggers, and grips to come up with a G3A3 that looks exactly like a PSG1 or MSG90.
Then.....for some fun.....the HK GMG, the direct competition of the MK19 fully automatic grenade launcher, capable of firing 40 rounds per minute.
Then, the HK USP Machine Pistol, with a 20 round mag and a 1250rpm fire rate.
If you want pictures, tell me....
Plus, the VP70 was 3RDBurst and single shot with the same (with stock) weapon, was not available in single shot only, with stock, to my knowledge, because the stock was the rate of fire selector and without it the gun simply fired single shot...
My friend Scott, who knows all about HK stuff, said
"H&K VP70 was the first polymer-framed pistol produced. The pistol, chambered in 9x19, was produced in 1970 but it didn't sell very well. It had, among other things, a nasty trigger pull (about 18 pounds). The pistol was however capable of firing in burst (3 rounds) with the attachment of a special stock, which also served as a holster."
The VP70M was with stock, in 3rd burst and single shot, the VP70Z was single shot without stock. Both models fired from a 12 round magazine.
It did not sell very well due to the long trigger pull and tendency to jam thanks to the high rate of fire while firing 3 round bursts.
"Pain heals. Chicks dig scars. Glory lasts forever." - Shane Falco, aka Keanu Reeves, in The Replacements
« Reply #4 on: May 08, 2001, 11:31:18 pm »
Well, today I added the VP70 both select fire with stock and the single fire model without. I also added the P-9. You know I toyed with the idea of doing the grenade launcher, but I don't think it is very realistic to be running through the Estate map with a automatic grenade launcher that probably weighs more than you do.
Ghost
« Reply #5 on: May 09, 2001, 01:28:37 am »
it weighs over 100 pounds, requiring a 3 man crew to service and fire it. it is also mounted on the Cav Scout Hummers.
Page created in 0.066 seconds with 19 queries.
