September 29, 2024, 09:33:20 pm
| | |-+  HELP!!!
Author Topic: HELP!!!  (Read 1126 times)
« on: June 13, 2001, 09:49:47 pm »
UO, RS, and my editors no longer work. I get the following message:
URBANOPERATIONS caused an invalid page fault in
module URBANOPERATIONS.EXE at 017f:006b17d7.
Registers:
EAX=00000000 CS=017f EIP=006b17d7 EFLGS=00010246
EBX=00000000 SS=0187 ESP=00adeb58 EBP=44200000
ECX=00000000 DS=0187 ESI=01342c38 FS=1ad7
EDX=01475b00 ES=0187 EDI=000005d8 GS=0000
Bytes at CS:EIP:
89 91 14 01 00 00 8b 46 70 8b 4e 78 89 88 18 01
Stack dump:
01342c38 01486d00 00adeb88 007a96eb ffffffff 0068efa7 44200000 43f00000 01342c38 43f00000 00348300 00adebb0 00adebb0 007a8dee ffffffff 0068eb9f
I uninstalled and then reinstalled both programs and patched them with no luck. Heeeeeellllllpppppp!!!
Ghost
MY OTHER CAR IS A HK PSG1
« Reply #1 on: June 13, 2001, 10:20:24 pm »
Sounds like your problem is in the medula oblongata.
"Pain heals. Chicks dig scars. Glory lasts forever." - Shane Falco, aka Keanu Reeves, in The Replacements
« Reply #2 on: June 14, 2001, 08:23:03 am »
Page faults are a lotta times caused by bad RAM, the stack dump could be a result of the same thing, a processor error, or a seperate software error. If you have more than 1 RAM chip in there, take one out, and try again, if it still screws up, put that one back and take out the other one(s). That can at least isolate the error if it is RAM related. If it still errors up no matter what RAM is in it, make sure your CPU fan is working right. Has it been hot last couple days? That's a possibility.
Lastly, if it's a software error, throw the windows 98 CD back in and boot off of a floppy system disk, and at the A:, type setup. That will launch the windows installation, but don't worry, it will only restore windows files, everything else will be untouched. DO that last, and if it's a software error that will  95% most likely fix it.
If this all fails, you could have a bad processor, or possibly (gulp) motherboard. These are less likely, but I see 'em every day so I can't say it doesn't happen...
Hope that helps! Grin
« Reply #3 on: June 14, 2001, 11:42:14 am »
Wow! Got it fixed finally. Really weird only UO Editor and R/S and U/O were effected. I ran a virus check, scan disk, and then finally ran the Windows Setup again and reinstalled R/S and U/O and magically that worked. Whew!!!
« Reply #4 on: June 14, 2001, 12:12:50 pm »
good deal Grin
Page created in 0.066 seconds with 19 queries.
